{"product_id":"shaper-tapered-ball-nose-router-bit-11-deg-1-4-shank","title":"Shaper Tapered Ball Nose Router Bit 11 Deg 1\/4\" shank","description":"\u003cp\u003eThe 11\u003cspecial id=\"8\"\u003e\u003c\/special\u003e Tapered Ball Nose Bit is solid carbide making it ideal for a wide variety of specialty applications that require tapered cuts. The small ball nose end 1.6mm at the tip tapers to 6.35mm at its full cutting depth of 25.4mm.\u003c\/p\u003e\u003cp\u003eIt offers good chip extraction and durability and can handle a wide range of cuts, from deep profile contouring to cutting wedged tenons for custom joinery. The ball nose end leaves a smooth rounded channel finish and the four-flute geometry and solid carbide composition help to ensure cutter longevity.\u003c\/p\u003e\u003cp\u003eOverall Length: 63,5 mm (2.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003eShank Diameter: 6,35 mm (1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003eCutter Angle: 11\u003cspecial id=\"8\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eCutter Length: 25,4 mm (1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e\u003cp\u003eGeometry: Conical, Spiral, Ball Nose\u003c\/p\u003e\u003cp\u003eMaterial: Solid Carbide\u003c\/p\u003e\u003cp\u003eCutter Diameter: 1,5875 mm (1\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e","brand":"Shaper","offers":[{"title":"Default Title","offer_id":54118466683227,"sku":"109284","price":51.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109284_xl.jpg?v=1789781277","url":"https:\/\/www.axminstertools.com\/products\/shaper-tapered-ball-nose-router-bit-11-deg-1-4-shank","provider":"Axminster Tools","version":"1.0","type":"link"}
