{"product_id":"shaper-up-spiral-flat-router-bit-4-x-15mm-8mm-shank","title":"Shaper Up-Spiral Flat Router Bit 4 x 15mm 8mm Shank","description":"\u003cp\u003eThis 4mm cutter is designed with extra reach thanks to the 15mm cutting length, which allows you to make deep passes. The solid carbide stays sharp even after hours of use and the two flute upcut gives a good cut quality in a wide range of wood species, including plywood, MDF and all hardwoods. This cutter is designed for high feed rates and offers stability during deep roughing passes and a good cut finish on deep finishing passes.\u003c\/p\u003e\u003cp\u003eOverall Length: 80mm\u003c\/p\u003e\u003cp\u003eShank Diameter: 8mm\u003c\/p\u003e\u003cp\u003eCutter Diameter: 4mm\u003c\/p\u003e\u003cp\u003eCutter Length: 15mm\u003c\/p\u003e\u003cp\u003eUsable Length: 30mm\u003c\/p\u003e\u003cp\u003eGeometry: Upcut, Spiral, 2 flute\u003c\/p\u003e\u003cp\u003eMaterial: Solid Carbide\u003c\/p\u003e","brand":"Shaper","offers":[{"title":"Default Title","offer_id":54118495322459,"sku":"109786","price":71.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109786_xl.jpg?v=1789782627","url":"https:\/\/www.axminstertools.com\/products\/shaper-up-spiral-flat-router-bit-4-x-15mm-8mm-shank","provider":"Axminster Tools","version":"1.0","type":"link"}
