Shaper
Shaper Up-Spiral Flat Router Bit 4 x 15mm 8mm Shank
SKU: 109786
£71.00
£59.17 Excl. VAT
  • 4mm diameter with a 15mm depth of cut for extra reach
  • Designed for deep roughing and finishing passes
  • Suitable for a wide range of wood materials
This 4mm cutter is designed with extra reach thanks to the 15mm cutting length, which allows you to make deep passes. The solid carbide stays sharp even after hours of use and the two flute upcut gives a good cut quality in a wide range of wood species, including plywood, MDF and all hardwoods. This cutter is designed for high feed rates and offers stability during deep roughing passes and a good cut finish on deep finishing passes.
Overall Length: 80mm
Shank Diameter: 8mm
Cutter Diameter: 4mm
Cutter Length: 15mm
Usable Length: 30mm
Geometry: Upcut, Spiral, 2 flute
Material: Solid Carbide
Web Attribute Set Spiral Router Cutters
