The Shaper 6.35mm x 25.4mm (1/4x 1) Up-Spiral Bit instantly clears waste out of the cut. Made from solid carbide these cutters ensure a very clean and smooth fast action, greatly reducing tearout, leaving a smooth finish, and is extremely durable.
It has a 1/4” shank with the added benefit of a longer overall length and a longer cutting length for deeper passes and improved stability in deep channels.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Overall Length: 63,5 mm (2.1/2)
Shank Diameter: 6,35 mm (1/4)
Cutter Diameter: 6,35 mm (1/4)
Cutter Length: 25,4 mm (1)
Geometry: Upcut, Spiral, 2 Flute
Material: Solid Carbide
