GSHARP & Sharp Edge
Sharp Edge Replacement Hone Set
SKU: 114575
€29,00
  • Mono-crystalline diamond abrasive for fast, efficient sharpening
  • Sharpens square-edged tools from 3mm to 85mm wide
  • Designed for use with the Sharp Edge Complete Kit
Ideal for sharpening and honing chisels, plane irons, machine blades and spokeshave blades, this Sharp Edge Hone Set is designed for use with the Sharp Edge Complete Kit. Manufactured using mono-crystalline diamonds electroplated onto a durable nickel steel backing, these hones provide fast, consistent cutting performance and long-lasting durability. Suitable for sharpening square-edged tools from 3mm to 85mm wide.
Includes 200, 400, 800 and 1,500g.
Web Attribute Set Sharpening Stone Accessories
EAN Barcode 5052511148271
