Tools from Japan
Shinto Japanese Two-Handed Saw Rasp - 260mm
SKU: 200502
£27.48
£22.90 Excl. VAT
  • Double sided blade, coarse and fine
  • Open lattice construction, eliminates clogging
  • Tempered steel teeth, use on wood, laminates, non-ferrous metals, plastics, gypsum board
Shape up with the two-handled Japanese saw rasp. The 260 x 30mm blade is double sided, coarse one side and fine on the other. The open lattice of the blade eliminates clogging. Tempered steel cutting teeth, use on wood, laminates, non-ferrous metals, plastics, gypsum board etc.
Grade Coarse & Fine
Rasp Type Saw Rasp
Web Attribute Set Hand Rasps Rasp Length: 260 mm
EAN Barcode 4986744631013
