A replacement or spare blade for the Shokunin 240mm Dozuki Japanese saw. The blade thickness is only 0.3mm and tooth pitch of 1mm; it cuts smoothly and with great ease. The nickel plating protects against corrosion and prevents resin build-up. Easily changed by simply loosening the locking screw on the handle, remove the old blade and replace it with the new.
Shokunin
Shokunin Blade for Japanese Dozuki Saw - 240mm
| Blade Thickness | 0.30 mm |
| Additional Accessories | Yes |
| Web Attribute Set | Japanese Handsaws |
| EAN Barcode | 5052511101856 |
