A replacement or spare blade for the Shokunin 180mm Jushi Japanese saw. Perfect for accurate dovetail cuts with fine rip cutting teeth. This ultra thin, fine toothed saw blade allows precise, thin kerf, tear-free cuts. The tooth profile and hardening make this an ideal saw for cutting plastics. It cuts a variety of plastics from hard acrylic to PVC plumbing pipes. Easily changed by simply loosening the locking screw on the handle, remove the old blade and replace it with the new.
Blade Thickness 0.30 mm
Additional Accessories Yes
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511101917
