A replacement or spare blade for the Shokunin 240mm Tatebiki Japanese saw. An extremely thin blade and fine rip cutting teeth, perfect saw for cutting dovetails and other fine joints. The tooth pitch is 1.5mm equivalent to 17tpi. The set on the teeth is minimal so the blade has a very thin kerf and leaves a cleanly cut surface. Easily changed by simply loosening the locking screw on the handle, remove the old blade and replace it with the new.
Blade Thickness 0.30 mm
Additional Accessories Yes
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511101832
