The Shokunin Dozuki Universal Saw Blade is a replacement blade for the Shokunin Dozuki Universal Saw. Its versatile and high-quality blade is designed for both rip and crosscuts. Its impulse-hardened teeth ensure precision and durability, while the rustproof nickel plating protects against corrosion. The blade's 0.3mm thickness and 1.5mm tooth pitch allow for smooth, effortless cuts, leaving a clean finish with minimal effort. The stiff spine provides stability, enabling a 50mm depth of cut, making it ideal for intricate woodworking tasks.
Web Attribute Set Japanese Back Saws
EAN Barcode 5052511133994
