Shokunin
Shokunin Japanese Cabinet Makers Chisel
SKU: 113395
£21.98
  • Available in 3mm to 36mm sizes
  • Laminated high carbon steel blade
  • Excellent edge retention
  • Red oak handle for comfort and control
  • Traditional blue steel hoop
  • Ideal for joinery and cabinetmaking
  • Japanese quality, performance and value
The Shokunin Japanese Cabinet Makers Chisel is designed for precision woodworking, making it ideal for fine joinery, cabinetmaking, dovetail work and general bench tasks. Whether you're cleaning up joints, paring end grain or making delicate adjustments, the finely ground blade delivers excellent control and accuracy. Available in a range of sizes from 3mm to 36mm, you can choose the width best suited to your work, from intricate detail tasks through to broader paring and chopping applications.
Each chisel features a laminated high carbon steel blade, combining a hard cutting edge with a more resilient backing layer for excellent edge retention and straightforward sharpening. The red oak handle provides a comfortable, balanced grip, while the traditional blue steel hoop helps protect the handle when used with a woodworking mallet. With an overall length of 225mm, each chisel is designed to offer a comfortable balance between control and cutting power.
Part of the Shokunin range, these chisels reflect the traditions of Japanese woodworking, combining skilled craftsmanship with carefully selected materials to deliver precise, dependable performance. Designed for woodworkers who value accuracy, sharpness and control, Shokunin tools offer the quality and reliability needed for everything from fine cabinetmaking to detailed joinery work.
Supplied in cardboard hanging packaging, the Shokunin Japanese Cabinet Makers Chisel makes a practical addition to any workshop. Available in 3mm, 6mm, 9mm, 12mm, 18mm, 24mm and 36mm sizes, the range allows you to build a versatile set capable of tackling a wide variety of woodworking applications.
Overall L x W x H 28cm x 6cm x 3cm
Chisel Blade Width 3 mm
Web Attribute Set Wood Chisels
EAN Barcode 5052511145201
