{"product_id":"shokunin-japanese-flushcut-saw-125mm","title":"Shokunin Japanese Flushcut Saw - 125mm","description":"\u003cp\u003eA small saw, traditionally used in Japanese joinery for flush trimming protruding wooden or bamboo nails, used to pin joints. The thin blade is incredibly flexible.  Even after bending beyond 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e it springs back true. The crosscut teeth of this saw have zero set. It can cut a dowel or tenon flush without marring the surrounding surface.\u003c\/p\u003e\u003cp\u003eWhen using this saw, it helps if you gently rest the fingers of your free hand on the back of the blade just behind the cut. This gives much greater control. The blade has two edges, a fine tooth pitch on one side for hardwoods and a slightly coarser pitch on the other for softwood. The blade length is 125mm fitted with a beechwood handle, overall length 270mm.\u003c\/p\u003e","brand":"Shokunin","offers":[{"title":"Default Title","offer_id":54118310216027,"sku":"105019","price":11.58,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105019_xl.jpg?v=1789774993","url":"https:\/\/www.axminstertools.com\/products\/shokunin-japanese-flushcut-saw-125mm","provider":"Axminster Tools","version":"1.0","type":"link"}
