What may appear at first glance to be an ordinary utility knife is actually a compact saw with a fine Japanese saw blade. This really is an ultra handy saw, whether you’re a model maker or occasionally need a saw for fine trimming. The 80mm blade fully retracts into the handle when not in use. Once retracted, it is protected from damage and allows you to carry the saw in a tool bag or pocket, or store it in a drawer.
The blade is 80mm long with a tooth pitch of 1.3mm(19.5tpi). The teeth are impulse hardened and the blade given a rustproof nickel plating. It cuts quickly on the pull stroke in wood, plywood, PVC pipe or bamboo.
Made in Japan.
Blade Thickness 0.45 mm
Web Attribute Set Japanese Handsaws
EAN Barcode 4903524011605
