The Shokunin Retractable Saw Blade is a replacement blade for Shokunin Retractable Saws. It is perfect for fine trimming and modelling tasks. This blade features impulse-hardened teeth for long-lasting sharpness and a rustproof nickel plating for enhanced durability. The 80mm blade fully retracts into the handle when not in use, protecting it from damage and making it easy to carry in a tool bag or pocket. With a tooth pitch of 1.3mm (19.5 TPI), it cuts quickly and smoothly on the pull stroke, making it suitable for wood, plywood, PVC pipe, and bamboo.
Shokunin
Shokunin Retractable Saw blade
| Web Attribute Set | Japanese Specialist Saws |
| EAN Barcode | 5052511133963 |
