FrogTape is a true innovation. Its super absorbent polymer along the tape's edge attracts the moisture in emulsion paints, creating a micro-barrier. The result is the sharpest lines possible, making touch-ups a thing of the past.
Delicate Surface FrogTape (yellow) is a low tack painter's masking tape for use on freshly painted surfaces (dried 24hrs minimum), wallpaper and newly plastered walls. If wished, you could apply it up to 60 days before you paint. It is UV resistant and can be applied in direct sunlight.
For best results remove FrogTape immediately after painting. It is ideal for creating stripes and paint effects. Sold in 55m(180ft) rolls, 24mm width.
