FrogTape is a true innovation. Its super absorbent polymer along the tape's edge attracts the moisture in emulsion paints, creating a micro-barrier. The result is the sharpest lines possible, making touch-ups a thing of the past.
FrogTape Multi-Surface (green) is a medium adhesion painter's tape designed for use on cured painted walls (dried 3 days minimum), wooden trim, glass and metal. After application, it will remove cleanly from most surfaces for up to 21 days (or 7 days in direct sunlight).
For best results remove FrogTape immediately after painting. It is ideal for creating stripes and paint effects. Sold in 55m (180ft) rolls, 36mm width. Supplied in 100% plastic free packaging
