The Elite Clamping Platform increases the surface area of your Elite workbench and adds even greater flexibility. The platform adds an extra 480mm to the length of your Elite bench and extends across the full 600mm width. It has 5 rows of 4 x 19mm bench dog holes across the top as well as a range of dog holes on the apron.
The platform comes with 4 bench dogs as standard (the holes will also take the optional accessory Sjöbergs ST11 holdfast) giving you hundreds of clamping options. Fixed with 2 robust steel brackets, the platform could form a separate work surface by attaching it to a wall.
Made of solid European beech and treated with a natural oil. The platform has a 110mm deep apron exactly matching the Elite benches, surrounding a 38mm thick top. It is suitable for the Elite 2000, Elite 1500 and SB119 workbenches and comes with brackets, fixing hardware and 4 x 19mm bench dogs.
Note:
Sjöbergs recommend that you keep your workbench where the humidity is between 40 & 55% all year round. Please see the care instructions on the downloadable documents for more information.
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
