A Sjöbergs Elite cabinetmaker’s bench is the ultimate workstation. Designed and built by Swedish craftsmen using selected European beech throughout.
The bench has great mass with its 85mm thick top and 110mm deep apron. The bench top is 1,805mm x 600mm giving plenty of space for larger projects. Double rows of 25.4mm(1) dog holes run along the length and across the width from each vice. The front and end vice open to 145mm and provide enormous clamping power across the bench’s surface.
The SM04 beech fronted storage unit features two sets of drawers and a double fronted cupboard. The unit provides space for hand and power tools and ensures everything is close to hand.
The Elite 200 comes with four round steel bench dogs which can also be used in the trestle legs.
The timber used is kiln dried and treated with a premium finishing oil. If your workshop is not a humidity controlled environment we recommend periodically re-oiling the bench on the top, underside and dog holes.
Sjöbergs 10 Years Guarantee
A genuine Sjöbergs bench comes with a 10 year guarantee and is marked with their official brand on each worktop - a sign that you are buying a workbench that keeps its promises.
Note:
Sjöbergs recommend that you keep your workbench where the humidity is between 40 & 55% all year round. Please see the care instructions on the downloadable documents for more information.
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
Overall L x W x H 1948 mm x 740 mm x 900 mm
Thickness of Top 85 mm
Web Attribute Set Woodworking Benches
EAN Barcode 7316705003103
