The Nordic Pro 1400 is a stable, robust and flexible bench. Built from the best quality beech to give you years of good service. It comes with a front and a tail vice, both with an opening of 115mm. The bench can be configured for use left or right handed. This is the perfect bench for demanding work in a smaller workshop. A double row of 19mm dog holes run from each of the vice locations, giving an endless opportunity to clamp your work. The bench top has a working surface of 1,290 x 500mm.
Note:
Sjöbergs recommend that you keep your workbench where the humidity is between 40 & 55% all year round. Please see the care instructions on the downloadable documents for more information.
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
