Sjobergs
Sjöbergs Original 1900 Workbench
SKU: 105603
€2.000,00
  • A joy to own and to work on' sturdy support for any woodworking project
  • Large worktop in selected European beech, front vice and full tail vice
  • Double row of round bench dog holes
  • Designed and built in Sweden
  • Supplied with set of bench dogs
The Sjöbergs Original 1900 Workbench is the perfect foundation for any workshop. It is designed and built in Sweden by one of Europe’s leading specialist manufacturers. Versatility combines with strength and quality to form a highly functional bench for a professional or a demanding home woodworker. Selected European beech used in the construction of the workbench bench ensures a long working life. Sjöbergs finish the bench with premium quality oil for protection. The workbench is strong, heavy and offers a comfortable working height. If you are a serious woodworker, this sturdy bench will support any project you undertake.
Includes features generally only found on benches costing much more. The worktop is 1,805mm long by 600mm wide (overall including vices 1,908mm x 662mm). The top is 60mm thick with a 110mm apron. The double row of round dogs is usable from both vices and across the worktop. The vices are capable of providing enormous clamping power as well as accuracy and smoothness. The front vice has an opening capacity of 120mm, the tail vice opens to 175mm.
Each Sjöbergs Original 1900 Workbench comes with a set of bench dogs, which also fit into the bench legs for horizontal support. Some self-assembly required, instructions included.
Sjöbergs 10 Years Guarantee
A genuine Sjöbergs bench comes with a 10 year guarantee and is marked with their official brand on each worktop - a sign that you are buying a workbench that keeps its promises.
Note:
Sjöbergs recommend that you keep your workbench where the humidity is between 40 & 55% all year round. Please see the care instructions on the downloadable documents for more information.
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
Overall L x W x H 1,908 mm x 662 mm x 900 mm
Thickness of Top 60 mm
Web Attribute Set Woodworking Benches
EAN Barcode 7316703819102
This is a Two-Person Large Delivery service. A two-person carrier dedicated to delivering larger and heavier consumer goods into your room of choice; whether in the home (including garden and garage) or at a business address. The carrier will inform you of your delivery options.
  • UK Mainland - £70
