Sjobergs
Sjöbergs Original 1900 Workbench & Storage Module SM05
SKU: 107842
€2.650,00
  • Solidly constructed bench using selected European beech
  • Large work surface with front and full tail vices
  • Spacious storage unit with cupboard, drawers and plane rack
The Sjöbergs Original 1900 Workbench is the perfect foundation for any workshop. Versatility combines with strength and quality, to form a highly functional bench. The selected European beech used throughout the construction is strong and tough. The SM05 storage unit features three drawers, a double cupboard and three hand plane shelves (it’s not a wine rack). The SM05 adds convenient storage and contributes to the bench's rigidity and overall weight.
The worktop is 1,805mm long by 600mm wide and is 60mm thick with a 110mm apron. The double row of round dogs is usable from both vices and across the worktop. The front vice has an opening capacity of 120mm; the tail vice opens to 175mm. Each Original 1900 Workbench comes with a set of four 25.4mm(1) bench dogs, which also fit into the bench legs for horizontal support. Some self-assembly is required, instructions are included.
A genuine Sjöbergs bench comes with a 10 year guarantee, a sign that you are buying a workbench that keeps its promises.
Note:
Sjöbergs recommend that you keep your workbench where the humidity is between 40 & 55% all year round. Please see the care instructions on the downloadable documents for more information.
Due to environmental factors outside of our control, we cannot warrant or accept returns for timber movement.
Overall L x W x H 1,908 mm x 662 mm x 900 mm
Thickness of Top 60 mm
Web Attribute Set Woodworking Benches
EAN Barcode 7316705008108
