With a Sjöbergs Smart Clamper you can add quality woodworking/hobby vice anywhere. It makes a versatile additional vice in an existing workshop or an easily transportable vice for mobile woodworkers. The Smart Clamper is made from solid beech wood, chosen for its tough resilience and fitted with a strong vice with galvanised steel guide rods. The vice opens to a maximum of 115mm, the jaw is 300mm long. The total width of the Smart Clamper is 400mm. The vice can easily be transported or fixed at any table or bench with clamps or screws. Sjöbergs Smart Clamper can also be used as a vice when you want to build your own bench.
For greater versatility the front jaw can be fitted either flush with the rear jaw or protruding above the rear jaw. This offers more options when fitting the Smart Clamper to a worktable.
Weight:4.5kg.
Overall L x W x H 400 mm x 430 mm x 100 mm
Manufacturer Part Number 33330
Web Attribute Set Woodworking Vices
EAN Barcode 7316703330102
