With these specially designed HSS cutters, you can use your Souber DBB morticer to fit locks into aluminium doors. Available in various diameters, the cutters provide you with the range you need to cut a lock slot in an aluminium door. The screw thread mount fits DBB morticers manufactured from October 2009 onwards.
Souber
Souber Lock Jig Aluminium Cutter HSS
| Cutter Diameter | 19 mm (3/4) |
| Web Attribute Set | Drilling Guides |
| EAN Barcode | 5060082785672 |
