These are additional, spare or replacement TCT Wood Cutters for the Souber Small Bore System. They fit directly onto the end of the Small Bore Shaft. These tungsten carbide tipped cutters have a high cutting speed and are designed for fitting locks into wooden doors. The system leaves a clean and precise cut.
The Souber small bore system fits onto standard DBB morticer jig for fitting smaller locks that are between 12mm and 15mm thick.
Cutter Diameter 13.2 mm
Web Attribute Set Drilling Guides
EAN Barcode 5060082786655
