Spectre™ Advanced Deck & Outdoor Screws are engineered for strong, reliable fixing in demanding exterior environments. Featuring a countersunk, pozidriv‑compatible recessed head and a durable green corrosion‑resistant coating, they deliver clean, long‑lasting performance. The sawtooth thread helps prevent timber splitting, while the built‑in reamer reduces jacking for a tighter fit. Surface‑hardened and equipped with a quick‑start Type 17 slash point, these screws drive smoothly and efficiently. Fully CE approved for load‑bearing timber construction.
Pack Quantity 200
Screw Size\Gauge 4.5 mm
Screw Length 50 mm
Web Attribute Set Wood Screws
EAN Barcode 5028485234180
