The SP50K is a dual action (press down for air and back for paint) internal mix (air/paint mix inside airbrush giving a fine dot spray pattern) airbrush. This airbrush kit can be used for both fine detail and larger coverage work and has a fluid control knob for easy adjustment, making for extremely accurate spraying. It can be used with most paints, acrylics, enamels, inks and lacquers. This is a truly multi-purpose airbrush which can be used for a multitude of applications including automotive custom spraying, craft, illustrating, stencilling, cake decorating, fine scale modelling, fabric painting, toy and sign painting, ceramics, tanning, taxidermy, leather work and lacquering. Spray pattern approx 1.6 - 38mm. Kit includes SP50 airbrush, 2 x 3/4 oz paint jars, vinyl hose, regulator adaptor for air propellant, 300ml air propellant and 150ml airbrush cleaner.
Spraycraft
SprayCraft SP50K Dual Action Airbrush Kit
| Web Attribute Set | Air Brushes |
| EAN Barcode | 5060030669849 |
