The SprayCraft SP66 Airbrush & Compressor Kit is very easy to set up and even easier to use.
The maintenance free, oil-less air compressor is compact, portable and designed to neatly store away when not in use. It has a maximum working pressure of 50psi and is fully adjustable allowing traditional spraying at lower pressures, or spraying metallic paints at higher pressure.
The compressor’s case features an integral handy airbrush holder. The kit includes a SprayCraft SP65 gravity feed, dual-action, airbrush with 2m of braided hose. Gravity feed airbrushes require less air pressure as gravity helps draw the paint to the tip.
The SP65 airbrush comes with a 7cc fluid cup with lid and has a 0.35mm nozzle. It is suitable for standard and metallic colours.
Additional Accessories No
Web Attribute Set Air Brush Compressors
EAN Barcode 5060252024570
