This airbrush kit allows woodturners or serious hobbyists to use multiple airbrushes, without having to constantly clean and change over the needles. It includes four SP50 airbrushes (two fitted with 0.3mm needles and two with 0.5mm needles). The SP50 is a dual action (press down for air and back for paint), internal mix (air/paint mix inside the airbrush giving a fine dot spray pattern) airbrush. It is ideal both fine detail and larger coverage work and has a fluid control knob for easy adjustment, making for extremely accurate spraying.
This multi-purpose airbrush can perform many other applications including automotive custom spraying, craft, illustrating, stencilling, cake decorating, fine scale modelling, fabric painting, toy and sign painting, ceramics, tanning, taxidermy, leather work and lacquering. Spray pattern approx 1.6-38mm. The kit also contains four quick release airbrush adaptors, a quick release hose adaptor and braided air hose.
Additional Accessories No
Web Attribute Set Air Brushes
EAN Barcode 5060252029438
