This pressure-cast light metal level has two milled measuring surfaces. It is robust and very practical: its two handholds make it very comfortable to use. 3-vials - the horizontal vial can be viewed from 4-sides and the vertical vials from 3-sides. Accuracy: ±0.5mm/m in normal and overhead positions.
Level Length 600 mm (24)
Web Attribute Set Levels
EAN Barcode 4005069025441
