A lightweight, precise level made from rectangular aluminium box section with internal ribs for additional stiffness. The end caps, which are fitted with stoppers on one side to provide grip when the level is used vertically, can be removed for close-up work. The levels have one horizontal and two plumb vials. N.b Levels over 1,200 mm do not have milled surfaces.
Level Length 2,400 mm (96)
Web Attribute Set Levels
EAN Barcode 4005069152321
