Stabila
Stabila LT30 - Telescopic Laser Pole 135-365cm
SKU: 102945
£78.88
£65.73 Excl. VAT
  • Professional Telescopic Laser Pole all steel construction
  • Twist-lock for rapid adjustment, lever handle locks in position
  • Mounting-platform includes 1/4 x 20 and 5/8 x 11 tripod threads
  • Suitable for many other brands of laser level
  • Doubles up as a temporary prop, max loading of 30kg
  • Extends from 1.35m closed to 3.65m fully extended
  • Weighs 2.7kg
A professional quality Telescopic Laser Pole as you would expect from Stabila. The LT30 is all steel construction for complete durability. The telescopic poles twist-lock, and a final lever handle locks the LT30 in position. The laser level mounting-platform includes both 1/4 x 20 and 5/8 x 11 threads, making it suitable for many other brands of level. The LT30 also doubles up as a temporary prop with a maximum loading of 30kg. The LT30 extends from 1.35m closed to 3.65m fully extended. Weight: 2.7kg.
Web Attribute Set Levels
EAN Barcode 4005069182380
