Stainless Steel Bottle Stopper (Pack 3)
SKU: 720724
€31,00
  • 3 bottle stopper kits
  • Solid stainless steel body
  • Classy looking wine bottle stopper
  • Perfect way to use up offcuts
  • Unique glue screw simplifies construction
  • Weighty teardrop shape; sits upright
  • Silicone rubber gasket seals bottle
  • Components only, does not include blank/material
Three stainless steel bottle stopper kits; one each for the red, the white and the rose.
Use some of those offcuts that are too good to waste into something practical and highly decorative. These classy, British made, solid stainless steel bottle stopper bodies only require you to turn a top piece to transform them into you own uniquely designed wine bottle stopper. The bodies are 66mm long and 25mm diameter at the top. The teardrop shape ensures they sit upright when placed in a bottle.
Pilot Hole - 8mm
Note: The Stopper’s spigot is 8mm diameter x 15mm long and knurled to help ensure a secure fixing. We recommend using CA or epoxy glue for extra security.
To make turning the bottle stopper a little easier, we recommend using the Axminster bottle stopper arbor (code 212316 for 1MT or 212317 for 2MT).
Difficulty Beginner
Web Attribute Set Project Kits Pilot Diameter: 8 mm
EAN Barcode 5052511119950
