The Stanley 0-20-92 is a multi-purpose 3-in-1 Saw set which offers the functionality of 3 different blades in one space saving design universal pull saw blade, metal saw blade and compass saw blade. It has an anti-slip ergonomic bi-material handle for optimum user comfort, the turn knob allows the user to conveniently store all three blades, switch blades, and tilt each blade into 6 different positions. The main blade utilizes a pull saw tooth configuration which is less likely to jam or bend while in use. Supplied with the following blades:250mm / 10 aggressive tooth 11 teeth per inch universal wood saw blade cuts on the pull stroke perfect for general woodwork and pruning. 200mm / 8 compass saw blade 9 teeth per inch for more detailed work.150mm / 6 metal hacksaw blade 24 teeth per inch for cutting metal pipes and rods.
Manufacturer Part Number 0-20-092
Web Attribute Set Handsaws
EAN Barcode 3253560200923
