The Stanley FatMax Blade Armour Magnetic Tape (8m) features a Tru-Zero end-hook, for accurate measurements every time. The Tru-Zero end-hook has a three-rivet fixing for extra security and a long life. The tape has further reinforcement in the form of Stanley’s BladeArmor, which gives extra protection to the most vulnerable first 80mm of any tape. The entire length is mylar coated for protection against rust and ensures the tape will be readable throughout its working life. The tip features a powerful rare earth magnet, which securely holds onto steel surfaces. This tape is an ideal choice when working on steel structures or erecting scaffolding etc. The 32mm wide blade is easy to read and has a massive 3.3m standout. The SlideLock feature holds blade securely in position and is useful as a brake on the tape return. The high-impact resistant ABS case features a durable moulded rubber grip for a secure hold on the tape even in the wet.
Manufacturer Part Number FMHT0-33868
Web Attribute Set Measuring Tapes
EAN Barcode 3253560338688
