Stanley
Stanley FatMax Mini Flush Cut Pull Saw - 125mm
SKU: 135792
£10.54
£8.78 Excl. VAT
  • Double sided blade for convenient cutting from the left or the right
  • Flexible blade enables the flush cutting of plugs and dowels
  • Soft-grip handle gives comfort and support during use
  • Cuts quickly and cleanly on the pull stroke
This FatMax pullsaw has a double sided blade for convenient cutting from the left or the right. A flexible blade enables the flush cutting of plugs and dowels as well as precise cutting such as dovetails, small joints and cut-offs. The soft-grip handle gives comfort and support during use. 23 tpi cut quickly and cleanly on the pull stroke. Length 125mm (5).
Manufacturer Part Number 0-20-331
Web Attribute Set Flushcut Saws
EAN Barcode 3253560203313
