Stanley
Stanley FatMax Tenon Saw 11tpi - 300mm
SKU: 701520
£10.86
£9.05 Excl. VAT
  • 300mm blade with reinforced back; bi-material handle for improved grip
  • Extra long life induction hardened triple edge tooth design
  • Fine 11tpi ideally suited to mitre or joint work
With a fine 11tpi, this tenon saw is ideally suited to mitre, or joint work where a smooth finish is highly desirable. Extra rigidity makes for a straighter cut and the long life induction hardened teeth, which cut on both the push and pull stroke, make this saw exceptionally good value for money. The bi-material handle, for improved grip, is screwed to the blade for extra strength and incorporates a 45 and 90 reference point.
Manufacturer Part Number 5-17-199
Blade Length 300 mm
Web Attribute Set Tenon Saws
EAN Barcode 3253565171990
