The Stanley Light-Duty Corner Clamp has independently adjustable jaws which can hold material of equal or varying thickness at right angles. Mounting holes allow the clamp to be securely attached to the work surfaces. It has a cast aluminium construction for long lasting durability. Specification: Throat Depth: 15mm. Clamping Capacity: 75mm. Weight: 275g.
Stanley
Stanley Light-Duty Corner Clamp 75mm
| Manufacturer Part Number | 0-83-121 |
| Web Attribute Set | Mitre Clamps |
| EAN Barcode | 3253560831219 |
