The Stanley Multi Angle Hobby Vice with its patented ball joint system allows you to rotate your project a full 360 and lock it at any angle in multiple positions for convenience and easy access. It has a 75mm wide jaw, opening to 70mm that will hold a wide range of items and has removable rubber jaw covers ideal for protecting delicate finishes. The large C-clamp mount is suited to heavy duty applications and attaches to work surfaces up to 60mm thick. Throat depth 40mm, clamping capacity 70mm, clamping Force 25kg.
Manufacturer Part Number 1-83-069
Jaw Width 75 mm
Web Attribute Set Miscellaneous Vices Jaw Opening: 70 mm
EAN Barcode 3253561830693
