The Micro Powerlock tape has a strong 19mm wide Mylar polyester film coated blade for durability and a large stand out. Mylar coating the blade means it is up to 10 times more resistant to abrasion than normal lacquered blades. The tru-zero end hook has 3-rivets and hook moves to compensate for accurate inside and outside measurements. The compact chrome plated plastic case is compact to hold and has a belt clip.
Manufacturer Part Number 0-33-553
Web Attribute Set Measuring Tapes
EAN Barcode 3253560335533
