The Stanley PowerLock®; BladeArmor®; Pocket Tape has a curved steel, Mylar®; coated blade that is up to 10 times more resistant to abrasion than normal lacquered blades. The first 100mm of the blade is reinforced with BladeArmor®; coating for maximum durability and reduced blade breakage. Tipped by a super-strong 3 rivet, automatically adjustable, tru-zero end hook. Supplied in a high-impact, chrome plated ABS plastic with a smooth, quick-grab autolocking mechanism and a conventional steel belt clip. Available with metric only or metric and imperial graduations.
Stanley
Stanley PowerLock® BladeArmor® Pocket Tape
| Manufacturer Part Number | 33531, 33527, 33526 |
| Graduations | Metric Only |
| Tape Length | 8 m |
| Web Attribute Set | Measuring Tapes |
| EAN Barcode | 3253560335274 |
