The metric roofing carpenters square is designed for all roofing calculations and also the layout of stairs. Made from tempered steel, buffed and with a clear protective finish and has 15 tables for rafter cuts, roofing pitches and rises etc. It is metric only, measuring 600mm x 400mm, graduated every 2mm, figured every 10mm on both sides.
Stanley
Stanley Roofing Square 600 x 400mm
| Manufacturer Part Number | 1-45-530 |
| Web Attribute Set | Builder's & Carpenter's Squares |
| EAN Barcode | 3253561455308 |
