{"product_id":"star-m-ceramic-edge-band-trimmer","title":"Star-M Ceramic Edge Band Trimmer","description":"\u003cp\u003eThe Star‑M Ceramic Edge Band Trimmer is a precision hand tool designed for trimming and chamfering edge banding flush with the workpiece. Made in Japan by Star‑M, a specialist cutting‑tool manufacturer since 1923, it combines excellent control with a durable ceramic cutting edge to deliver a consistently clean, professional finish.\u003c\/p\u003e\u003cp\u003eOnce edge banding has been applied, the trimmer is pulled along the edge to remove excess tape while simultaneously creating a subtle chamfer. This leaves an edge that not only looks refined but also feels smooth and intentional, rather than simply trimmed back. It works effortlessly on common edging materials such as pre‑glued veneer tape, PVC or ABS edging, and thin solid wood edging, making it ideal for furniture panels, cabinet doors, drawers, and carcass components.\u003c\/p\u003e\u003cp\u003eThe ceramic cutting edge is what really sets this trimmer apart. It remains sharp far longer than a steel blade, shrugs off resin and adhesive build‑up, and cuts cleanly without catching or tearing the edge banding. Its compact, well‑balanced design feels comfortable and natural in the hand, maintaining a high level of control and consistency even over longer runs. It quickly becomes one of those tools you instinctively reach for - smooth, quiet, and deeply satisfying to use.\u003c\/p\u003e\u003cp\u003eTwo chamfer options are available to suit different applications. The 0.6mm chamfer is ideal for finer furniture work and veneered panels where a subtle, understated edge is required, while the 1mm chamfer provides a slightly bolder bevel, well suited to cabinet work and edges that benefit from a little extra durability.\u003c\/p\u003e\u003cp\u003eFor best results, use it alongside a standard flush edge‑banding trimmer for thicker tape, finishing with light sanding if you want to soften the chamfer further. Whether used on its own or as part of a full edging setup, it’s a small but highly effective finishing tool that quickly earns its place in the workshop.\u003c\/p\u003e","brand":"STAR M","offers":[{"title":"0.6 mm","offer_id":54165090337115,"sku":"113027","price":22.28,"currency_code":"GBP","in_stock":false},{"title":"1 mm","offer_id":54165090369883,"sku":"113028","price":26.68,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113028_xl.jpg?v=1790115782","url":"https:\/\/www.axminstertools.com\/products\/star-m-ceramic-edge-band-trimmer","provider":"Axminster Tools","version":"1.0","type":"link"}
