Feeler gauges are used to adjust tappets, spark plugs, distributor points, check bearing clearances and gear play, fitting pistons, rings and pins and gauging narrow slots. Leaves are tempered steel, easily removed and replaced. There is a locking device on all sets.
Starrett
Starrett 66MA Feeler Gauge 20 Piece Set 0.05-1mm
| Web Attribute Set | Miscellaneous Gauges |
