{"product_id":"starrett-s1106-portable-benchtop-bandsaw-230v","title":"Starrett S1106 Portable Benchtop Bandsaw 230V","description":"\u003cp\u003eThe Starrett S1106 Portable Benchtop Bandsaw delivers accurate, reliable cutting performance in a compact, workshop friendly design. Ideal for cutting solid metal blocks, tubes and profiles, this metal cutting bandsaw combines robust construction with versatile functionality, making it an excellent choice for fabrication, engineering and maintenance applications.\u003c\/p\u003e\u003cp\u003eBuilt with a reinforced frame and sturdy base, the S1106 Bandsaw minimises vibration for smoother, quieter operation and improved cutting accuracy. Fixed and adjustable bearing blade guides help maintain precise, straight cuts. Offering a cutting capacity of up to 125mm for tubes and profiles, and 30mm for solid materials, it handles a wide range of metalworking tasks with ease. The adjustable bow also enables accurate mitre cuts up to 60°, adding further versatility to the machine.\u003c\/p\u003e\u003cp\u003ePowered by an 850W motor, the saw offers both manual and automatic operating modes, allowing you to work efficiently across a wide range of cutting tasks. Variable blade speeds from 30 to 80m\/min are easily adjusted via a simple dial, enabling you to optimise performance for different materials. For angled work, the bow adjusts quickly to produce accurate mitre cuts up to +60°.\u003c\/p\u003e\u003cp\u003eA 13mm bandsaw blade provides excellent versatility across multiple materials, while the quick blade installation and tensioning system makes setup and maintenance straightforward. The secure vice keeps workpieces firmly in position throughout the cut. Additional features include a measuring bar for repeatable cuts, a rapid on\/off switch and a limit switch that automatically stops the machine at the end of the cut.\u003c\/p\u003e\u003cp\u003eThe Starrett S1106 Portable Benchtop Bandsaw is a dependable metal cutting bandsaw that combines precision, versatility and durability in a compact footprint.\u003c\/p\u003e","brand":"Starrett","offers":[{"title":"Default Title","offer_id":54118867272027,"sku":"114560","price":479.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114560_xl.jpg?v=1789794944","url":"https:\/\/www.axminstertools.com\/products\/starrett-s1106-portable-benchtop-bandsaw-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
