The Ultimate Router Base Template Bushing is a great add on to The Ultimate Router Base. The 1.1/2 OD fits onto any standard 1 OD template guide. When used with a template and 1/2 router bit, the bit can be exactly positioned to either side of a cutting seam to create a perfectly matched seam. It is best used for curved joinery on hardwood table edges.
Designed for use with The Ultimate Router Base System. Exclusive to Axminster Tools in the UK, The Ultimate Router Base System will be the only router base you ever need.
