Titebond
Titebond Quick & Thick Multi-Surface Glue
SKU: 600201
£6.98
£5.82 Excl. VAT
  • 2 x Faster and 3 x Thicker than traditional PVA glues
  • Dries clear and is paintable, unaffected by finishes
  • Perfect for the workshop and home and craft projects
  • Designed for interior projects
  • Initial tack time 10-15 mins
  • Setting time 24 hours approximately
Titebond Quick and Thick is the thickest and fastest drying waterbased glue available. You can use it with porous or semi-porous materials and is ideal for wood, pottery, ceramic, stone, glass, fabrics and leather. It provides a strong initial tack with a fast setting speed. However, it does still give you enough time to realign your workpieces. Once set it gives you a bond that is stronger than the wood itself, it is unaffected by finishes and dries clear.
Setting Time 30 mins/24 hours
Suitable For Wood MDF Leather Cloth
Adhesive Type Thixotropic PVA
Available Sizes 237 ml (8 fl.oz)
Web Attribute Set General Woodworking Adhesives
EAN Barcode 37083024036
