The Tormek CW-220 Composite Honing Wheel is the clean way to remove a burr and put a final polish on your bevels and knife edges. The composite has polish amalgamated with its compound so there is no need to use any additional honing compounds or pastes. Its a no fuss no mess honing wheel. After using the grinding wheel, the honing wheel will help achieve the highest possible sharpness. You can also use it to "touch up" a knife. The CW-220 fits the Tormek T-8, Tormek T-7 and Tormek 2000.
Tip when honing!
Moisten the composite honing wheel with some water for a smoother honing. Use a sponge or cloth.
Web Attribute Set Felt Honing Wheels
EAN Barcode 7392485009580
