Tormek
Tormek KS-123 Knife Angle Setter
SKU: 111821
£40.78
£33.98 Excl. VAT
  • Exact angle setting on straight or tapered blades
  • Self-adjusting compatibility for ease of use
  • Geometric precision ensure consistent accuracy
The KS-123 Knife Angle Setter is your key to achieving precise sharpening angles for any type of knife. Whether you’re working with straight blades or tapered ones, this patented and sophisticated solution simplifies the angle setting process and ensures precision every time.
The KS-123 Knife Angle Setter is a compact and robust tool with dimensions of 156 mm in width, 58 mm in depth, and 70 mm in height. Crafted from durable cast zinc and composite materials, it is designed to fit all Tormek machines with a universal support, this analogue angle setter relies on exact geometric measurements for consistently accurate angle calculations. Its self-adjusting design accommodates different grinding or honing wheel diameters, making it a versatile addition to any sharpening setup.
Whether you’re a seasoned chef, a woodworking enthusiast, or simply someone who appreciates a well-sharpened knife, the KS-123 provides precise angle setting to enhance your sharpening process.
With the KS-123, upgrading your knife sharpening is effortless – it’s precision made as easy as 1-2-3!
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485005094
