Tormek
Tormek MSK-200 EzyLock Main Shaft Kit for T-4
SKU: 211103
£52.28
£43.57 Excl. VAT
  • Shaft, washer are all made of stainless steel
  • Composite Ezylock nut
  • EzyLock makes it very easy to change grindstones
  • Kit includes: Shaft, EzyLock Nut, Nylon bearings, cross pin, stone washer and drive wheel washer
  • MSK-200 fits the T-3 and any other 200mm Tormek machines
The Tormek EzyLock shaft kit includes a self-tightening knob to secure the grindstone. No tools are required and you don’t need to exert any pressure on the nut to secure the grindstone. EzyLock makes it very easy to change grindstones, from the standard aluminium oxide to either of the specialty stones. The shaft and washer are made of stainless steel. The nut is a composite material. The kit includes an EzyLock Shaft, EzyLock Nut, two replacement nylon bearings, cross pin, stone washer and drive wheel washer. The MSK-200 fits the T-4 and any other 200mm Tormek machine.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485001249
