Tormek
Tormek SP-650 Stone Grader
SKU: 910080
€30,00
  • Unique double-sided stone
  • Can also be used to dress or open out stone
You do not want to be without this double-sided grader. Use the coarse side regularly to keep the stone open and effective. Also, this will practically get you two grindstones in one. The fine side will change the function of the Tormek grindstone from fast grinding at 220 grit to fine grinding at a 1000 grit surface. Standard with the T-4 and T8 machines.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485002116
